Buderus g234x stuck at 200 on logmatic
San
Member Posts: 3
in Gas Heating
Need help here to fix my boiler.
I have a 10 year old Budweiser g234x.the boiler remained on as had some issue with my air-handlers and they were turned off for the entire day. So the boiler is now stuck at 200 and doesn’t start. Only time it starts and fires is if I turn it off and the boiler cools down, but again reached 200 very fast but no hot air from the vents. Also the circulator pumps keep running when it fires. Tried resetting the spill switch and also tried manually resetting the log magic but no luck. For now have turned the boiler and air handlers off. Looks like the the boiler kept on with air handlers off caused something to not work on the boiler now. Any help is appreciated.
No cirulation from the boiler to the air handler , what was your issue with the air handlers ? Valve off , need to purge out the air ?
My air handlers turned off with the boiler running. So is it low on water or need to purge the air? How can we purge the air out?0
There should be purge valve set up at the boiler . What is the pressure on the system ?
