Rheem HW Heater won’t light
Slowhand63
Member Posts: 80
Woke up to no HW. Rheem 50g HW heater just over a year old. I can light the pilot light by holding down the button - stays lit while I’m holding the button down. To turn the knob to “on” I need to release the button. As soon as I do the pilot light goes out.
I’m thinking it’s the thermocouple, but could also be the gas valve, or ? Appreciate any suggestions or things I can check. If it’s a thermocouple, any diagrams or photos on how to replace would be appreciated.
How does the pilot flame around the thermocouple look?
It is probably a bad thermocouple.
Replacement varies by model.
Got pictures? Especially the flame."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
All the new heaters I see have a push button spark igniter. When the pilot lites a light will blink. Are you sure about the one year old.0
Thanks for the comments on my post. I’d say the flame was unimpressive - smaller than expected, small blue cone about 1/2 - 3/4” high. The push button spark generator works 50-75% of the time, but a few snaps and it lights the pilot. The pilot will stay lit as long as I keep the button pressed. After doing some additional research I’m guessing the thermocouple. Also cheapest and easiest to change. Does anyone know if a universal (Home Depot) thermocouple will work? I’ve read posts that suggest only one from Rheem will work. Also - the system is “closed” - any concerns re the gasket or should it be okay to simply remove the screws and then replace? Thx0
How long did you hold the button? I think some of the fancy ones with blinky lights use a thermopile to generate enough power for the control. I don't think there are any gaskets, just a screen to keep a flame from spreading to flammable vapors outside the combustion chamber.0
I held the button for 90 seconds or more.0
Most likely the thermocouple. there us a way to check it with a voltmeter0
Does anyone know if a universal thermocouple will work on a Rheem?0
Depends on the valve. Probably if it uses a standard coaxial type thermocouple. Rheem has made hundreds of millions of water heaters. The usually bought the valve from someone else.0
Thermocouples are "consumable" items. Unusual for a one-yr.-old one to go bad. Just get a thermocouple of a similar length. In fact take out the old(bad) one and take it with you to the store in order to match it.0
Hi, A possible simple fix is to loosen and retighten the connection between thermocouple and gas valve. Sometimes that connection is loose or gets a bit of corrosion. Also, the pilot flame should make good contact with the thermocouple and make the tip glow a dark red. If it isn’t doing that, maybe some dust has gotten into the pilot orifice.
Yours, Larry1
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
