Good one (air filter)
GW
Member Posts: 4,989
What happened to “heating hell”?
Pc Timothy Johnson
3
Well, you can only flip it once, or...0
Wow!! I've seen plenty that have been dated from a few years back, I never saw one with that description.0
That’s one way to try and keep it clean, blow the dirt back out of it.2
maybe it was rotated 180 degrees in the same plane to even out the loading unnecessarily , not front to back0
Lol, I had one two weeks ago from 6/2019. I saw it and said "your furnace has been overheating. The air filter hasn't been changed in a long time. " Her response was, "I just put that in a couple of months ago." I had to show her the date that I wrote on it the last time I was there and changed it for her. I always do that if it is obvious that the owner leaves the filter in too long.3
- 110 Chimneys & Flues
- 978 Plumbing
- 387 Solar
- 17 Recall Announcements
