Good one (air filter)
GW
Member Posts: 5,135
What happened to “heating hell”?
Pc Timothy Johnson
3
Well, you can only flip it once, or...0
Wow!! I've seen plenty that have been dated from a few years back, I never saw one with that description.0
That’s one way to try and keep it clean, blow the dirt back out of it.
2 -
maybe it was rotated 180 degrees in the same plane to even out the loading unnecessarily , not front to back0
Lol, I had one two weeks ago from 6/2019. I saw it and said "your furnace has been overheating. The air filter hasn't been changed in a long time. " Her response was, "I just put that in a couple of months ago." I had to show her the date that I wrote on it the last time I was there and changed it for her. I always do that if it is obvious that the owner leaves the filter in too long.3
