Good one (air filter)
GW
GW Member Posts: 5,134
What happened to “heating hell”?
Pc Timothy Johnson
Gary Wilson
Wilson Services, Inc
Northampton, MA
gary@wilsonph.com
ttekushan_3SuperTechDZoro
  • bucksnort
    bucksnort Member Posts: 167
    “Think of how stupid the average person is, and realize half of them are stupider than that.”
    ― George Carlin
    GWDZoroCLamb
  • sunlight33
    sunlight33 Member Posts: 378
    Well, you can only flip it once, or...
  • wesPA
    wesPA Member Posts: 41
    Wow!! I've seen plenty that have been dated from a few years back,  I never saw one with that description.
  • KC_Jones
    KC_Jones Member Posts: 5,902
    That’s one way to try and keep it clean, blow the dirt back out of it.   :D
    2014 Weil Mclain EG-40
    GWCanucker
  • ttekushan_3
    ttekushan_3 Member Posts: 964
    Don’t worry. The A/C coil will pick it up.
    Terry T
    GW
    mattmia2 Member Posts: 15,371
    maybe it was rotated 180 degrees in the same plane to even out the loading unnecessarily , not front to back
  • SuperTech
    SuperTech Member Posts: 2,633
    Lol, I had one two weeks ago from 6/2019. I saw it and said "your furnace has been overheating.  The air filter hasn't been changed in a long time. " Her response was,  "I just put that in a couple of months ago." I had to show her the date that I wrote on it the last time I was there and changed it for her. I always do that if it is obvious that the owner leaves the filter in too long.
    GWbucksnortDZoro
