Old Bell Gossett Pump
todd_14
Member Posts: 18
I have 2 old B&G pumps that are Factory GREEN - not red. They are model PV-5.
Vertical marathon motors supported on on springs.
Can anybody tell me approx year and supply a link to original catalog and pump curves?
I also have an old B&G pump with a horizontal 1/6 hp motor. It has a 189103 bearing assembly. How do I determine the actual pump model?
The horizontal motor pump looks like it has some #s on it. @DanHolohan is the expert on those pumps maybe he will respond0
I believe that is their PD pump.Retired and loving it.0
Horizontal kinda looks like an LD 2-1/2 or 3 but as Dan says maybe a Pd. Never seen the B&G old vertical, worked on many old Thrush and Edward's verticals. Pretty cool.0
It should have LD Or PD cast into veloute. Or just 2 1/2. We still stock 100s of parts for b&g parts and fix them weekly. They really were good pumps. Maybe not the.most efficient but long lived. All parts for red pump still available. Pump motors although are $$$ for a 1/6 hp motor comparatively to cartridge circs.0
I'm going by the bearing assembly. I recall the PD used that one. Gotta stretch my memory pretty far to pull that one out.Retired and loving it.0
The old B&G P1-5 was a 1/6 HP horizontal pump with a 4 bolt circular flange 1-1/4". I have never seen a vertical version of it before. The earliest B&G Forced Circulation boosters were horizontal with the direction of flow from the sides instead of top to bottom so I guess it wasn't much of a stretch to mount them vertically. amazing to see the OG B&G Logo on that pump! A modern B&G HV Series circulator would replace it, the performance will be close enough. Note that the modern 1-1/4" flange is oval two bolt. The second pump is a much more modern 2 NFI with an all bronze bearing assembly used as a replacement. Assuming both applications are for heating and not plumbing. Also assuming from the age of this post that this has all been resolved by now.Nick Ekdahl, CPD, GPDDirector of Training & EducationDawson Company0
- 87K THE MAIN WALL
- 112 Chimneys & Flues
- 106 Geothermal
- 980 Plumbing
- 388 Solar
