Parts for a older taco ZVC406 EXP
Le John
Member Posts: 250
Hi all - Anyone know where I can get the motherboard plastic prongs that hold the board in place. The plastic prongs broke off from the board.
Why/how did they break off?
I would have said look at a radio shack but unfortunately they are not around anymore...0
Not sure how they broke off @STEVEusaPA . I took the unit off an old tenant boiler and noticed movement inside the box. Sure enough the prongs looked broken off. It’s an old control but it works. If nothing else I’ll keep it for the 2 transformers.0
They are pretty standard. next time you replace a circuit board on a furnace or other control, look to see if they have what you need. There may already be something in your junk pile at the shop. (assumes that you do this for a living... otherwise, go to the local repair shop and ask to look thru their junkpile.)
1
