Whose manifold is this , need to replace actuators
Rich_49
Member Posts: 2,785
Can anyone assist in identifying whose ( manufacturer) manifold this is ? Actuators are bad , they are obsolete and trying to not replace manifolds also to keep costs down . No luck researching this myself so far .
732-751-1560
Rich McGrath 732-581-3833
732-751-1560
those valve heads are still available
Is it RTI of Long Island, Dave H of Taco was part of that company.
Wirsbo, Honeywell and Sparco used that actuator, I think they were all the same.Bob "hot rod" Rohr
Any idea where they are available ? Residio Honeywell discontinued them in March of 20' . I have not seen any of them from other manufacturers for quite some time .BillyO said:those valve heads are still available
732-751-1560
Rich McGrath 732-581-38330 -
Bob , First person I called was Dave when I saw the RTI brand . they made controls but Dave was not sure of the manifold origins .
732-751-1560
seen them on ebayBob "hot rod" Rohr
E bayBob "hot rod" Rohr
