Finding a contractor
salisboss
Member Posts: 34
So after dealing with another winter of air I finally talked my wife into spending the money this spring to reconfigure the piping on our boiler to 'pump away'. How do I go about finding a contractor to do the work without trying to talk me out of it? Are the contractors in the search down with pumping away. I would do it my self but our domestic hot water also comes from the boiler and I don't want to be without hot water that long if can help it.
@salisboss
Most everyone agrees that pumping away is the correct approach for a new install. But many old systems have pumped towards the expansion tank for years with no issues. It's all about the piping resistance in your system weather pumping toward the expansion tank works.
I suspect you may have other issues, but maybe not. Just don't wan't you to get your heart set on pumping away and then find it doesn't fix your issues. Pictures and a description of your problem will help.
Check "find a contractor" on this site. And post where you are located, someone will have a recommendation
@EBEBRATT-Ed is right on - air usually has a cause and the solution may be fairly simple. That being said, I would be inclined to install a SpiroVent air eliminator in the supply as a solution rather than pump away.0
The Spirovent will work much better if you Pump Away.All Steamed Up, Inc.
Consulting0 -
You don’t wanna install a Spirovent if you have a compression tank, only with a bladder tank.
Where are you located?Bob Boan
I have a bladder tank with an air scoop currently which doesn't have the requisite 18" of straight pipe. The air scoop and auto vent do nothing.Ironman said:You don’t wanna install a Spirovent if you have a compression tank, only with a bladder tank.
I am in NJ.0 -
You could try my NJ company Toro Plumbing & Mechanical
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
@salisboss you can reach me at
20188788560 -
Interesting, I did not know you could not use a spirovent without a bladder expansion tank.0
