What about this Fieldpiece combustion meter?
hot_rod
Member Posts: 26,594
Looking for a new tester, basically for my home use, keeping tabs on my two mod cons. Anybody using this entry level meter. I have other Fieldpiece meters, like the quality and durability.
I would like to know myself. Being retired but doing an occasional job I might pick one of those up if there any good0
Me, I am not a Fieldpiece fan. Nothing that I would to use all the time ...
It doesn't look like it measures CO. I think that would be a deal killer for me."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Yeah, I checked the manual no mention of Co0
No CO is a no GO.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
