Steam Radiator Plug Ringing Noise
jmhold
Member Posts: 10
Hello! I purchased a home built in the 1930's in November of last year with a single pipe steam heating system. After some "getting to know you" snafus, the system is working relatively well with a few caveats.
1. Most of the radiators in the house have a plug at the top/left or right side with a small "V" shaped hole that rings like an old rotary phone when the radiator is filling with steam. This noise is very distracting. (Though it may sound a little nuts, I assure you the noise isn't coming from the air vent. The ringing in the bedroom was so loud I covered the offending plug with some foil tape, which diminished the volume of the ringing significantly, so I could get a full night of sleep.)
2. I cannot find the main vent. With all the research I've done, I have never heard of a single pipe system that does not have a main line vent. Is it possible that my system doesn't have one? If so, should I have one installed?
Pictures of the plug??
Some early air vents were miniaturized, and this plug may be a malfunctioning example of that.
you could take it out and replace it with a real plug.
What is your pressure?—NBC0 -
That’s the original vent. I don’t think I’ve seen a picture of one in that good of shape. It might be making noise, but that’s kind of amazing.
@Steamhead2 -
you could maybe try cleaning it
here is a description of that vent:
https://heatinghelp.com/blog/doctor-bobs-radiator/1 -
To answer your other question, every one-pipe system should have main vent(s), but many don't. Mine didn't have one when I bought my house but it had a place where one used to be and I was able to easily restore it as one of the first improvements I made to my system.
Well...I sat in front of my boiler for a whole cycle and the pressure gage never moved. It's probably stuck or brokennicholas bonham-carter said:Remember that the settings on the pressuretrol may not match the actual pressures, if the pigtail is plugged.—NBC
Thanks for the link and suggestion. I'll have to see if I can find an article on how to clean them. My initial thought is to try and squirt white vinegar up there. Thoughts?mattmia2 said:you could maybe try cleaning it
- 50 Industry Classes
