which vent?
JU22
Member Posts: 7
It seems that I have a bad radiator vent. My varivalve is just leaking steam like crazy, and I am looking to replace it. The radiator in this room is probably undersized and is last to heat up in the house, but I cannot fix that at the moment. With this is mind, would a vent-rite be a bad choice? I was going to go for it since I see it recommended so many times on this forum until I read that vent-rites can be good in situations where the radiator is over-sized for the room...since it is the opposite case for me, any better suggestions? Thank you!!!
Pitch is good from what I can tell. Hope a new vent does the trick.0
Update: replaced the Varivalve with a Hoffman 1A and the problem is solved! Happy that this was a simple fix! Thank you for your advice/suggestions!0
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
