New Boiler
rjh1
Member Posts: 3
in Oil Heating
Installed a new Peerless WBV-03 boiler ,, before it comes on the blower runs for approximately 15 ish seconds . then it ignites ?? Why does the blower run before hand ??
It ignites fine -- don't understand ? Thanks
Awesome Thanks ! ! ! Much appreciated My old one was a Crown with a Beckett pump it didn't do it.. This one is also a Beckett system but a Peerless boiler unit0
Yep, newer designs. As well as clearing the combustion chamber and helping start a draft, the newer controls also allows the pump to build full pressure before the oil solenoid snaps on - prevents a dirty start from a low pressure build up, then snaps the oil off cleanly on stop - prevents a dirty shutdown from dribbling oil from the decaying pressure.
I'm surprised the contractor didn't explain that while going over the system with you.0
Well another inquiry please . . . . Where should the high temp be set to ?- Low temp ? and economy be set at ? there isn't a outside ambient temp sensor attached so I don't think the eco would be set ? There is NOT multiple zones.. In case that matters.. for those that helped before . . Yea the blower runs approximately 15 seconds then ignition0
All fuel pumps have a built in cut off. Adding the solenoid is of course much better for cleaner light offs and shut downs.MaxMercy said:Yep, newer designs. As well as clearing the combustion chamber and helping start a draft, the newer controls also allows the pump to build full pressure before the oil solenoid snaps on - prevents a dirty start from a low pressure build up, then snaps the oil off cleanly on stop - prevents a dirty shutdown from dribbling oil from the decaying pressure.
