Gas boiler question
maroo
Member Posts: 30
When the gas boiler starts cycling on it started today making a scraping noise it only does it once when it first cycles on then there’s this tapping noise that comes from the vents. What could be going on?
When the gas boiler starts cycling I keep hearing these noises through the vents first it was the bathroom vent now it’s the one in my room and kitchen it sounds like a crackling type of noise but it only occurs while the boiler is cycling then it stops. I didn’t hear this noise last winter and I’m concerned. Does anyone know what it could be?0
It’s like a crackling tapping noise I want to add. More so like a tapping sound0
Auto vent dampers make scrapping/scratching sound when they open before boiler fires.
Sound should last less than maybe 10 seconds.
What are the "vents" you mention. Send pictures of them and boiler.
That looks like baseboard hot water heaters, actually convectors.
There is usually a 3/4" copper tube with aluminum fins on the tube. The copper tube gets hot and expands a little as it heats up. Contracts when it cools. The higher the temperature the more it expands.
The fins are important as that makes the air move over the tube (convect) and heat up. If fins are dirty or bent then air movement in impeded and will not heat so well.
The tube is mounted on several plastic pads that allow it to move with expansion.
It may have a tinging sound as this happens.
If you hear a water fall or running water sound then the BB may have air in it and not heat so well.
Have you found your vent damper device?
Picture of the boiler showing all piping will be good.....back up.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
