1" G thread tailpieces
hot_rod
Member Posts: 26,579
More and more you will see components with the 1" G thread. This thread is commonly used on 3 way mixing valves. You see this connection inside many mod con boilers also, valves, pumps, etc.
At Caleffi there are 15 different products that install with a 1" G thread.
Here are 31 versions of the tailpieces available 1/2- 1. Sweat, press, NPT and both pex connections. Check valve versions also.
Does Caleffi also offer tailpieces for 2" G thread?Luke Stodola0
Who names these things? Is only the female side called the G fitting? Are they difficult to find? Plumbers have to get their minds out of the bedroom and back in the mechanical room!
And what, exactly, does "G-thread" mean in this application? A certain thread pitch, maybe?EdTheHeaterMan said:Who names these things? Is only the female side called the G fitting?
Consulting0 -
Its not actually called "G-thread", it is normally written as G followed by the nominal size (in inches). G1, G2 etc.
It is BSPP (British Standard Pipe, Parallel) aka ISO 228. Straight threads rather than tapered, with a gasket making the seal.Luke Stodola0 -
In this particular case I am looking for something with female G2 and female 2" NPT, but if you just offer the MIP I could certainly use a coupler. I am considering buying some Grundfos pumps off eBay but they have G2 threads instead of flanges. I'm guessing that's a European thing? If I understand it correctly, your tailpieces essentially functions like a union, and would allow easy replacement of the pump without the need for flanges.
I could certainly just stick with a standard flanged pump, but if you are saying we'll see these connections more and more maybe its a safe bet.
Thanks!
Luke Stodola0 -
Looks like a 2" nut, thread OD would be about 2-1/4, like this.
Biggest fitting that will go thru that nut would be a 1-1/2 NPT or sweat. If you find a 2" NPT or sweat tail it will be a drop nut style, since it is too large to fit thru the nut..
Caleffi F000094 is a 1-1/2" sweat tailpiece with fiber washer
2" nut is R53003
NA 10715 is a 1-1/2 press tailpiece.
Be careful buying Euro stuff, it will be most likely be 230V 50 Hz, although it does seem to run on 240V, a hot and neutral leg. I see on some recent Euro pumps 208- 240V, 50- 60Hz on the label.Bob "hot rod" Rohr
Living the hydronic dream1 -
Thank you! Exactly what I was looking for. Still may end up sticking with a US model though to make any future swap-outs easier.Luke Stodola0
NPT works fine, why wouldn't it? Although the US is one of the few places it is used extensively. Straight threads and hemp is the go to in most of the world for assembling threaded pipe. Once you get use to it is actually is very accurate as the thread "make up"is not dependent on the thread length or quality. You end up exactly where you want to be on length.Youngplumber said:Can I ask why? Does npt not work anymore? Any reason to complicate threads of all things?
The G thread and tailpieces give you an easily serviced joint for pumps, valves, boilers.
Again the US and Canada is about the only flanged circulator market. You see that straight thread connection on pretty much every Euro based boiler.
The automotive industry went metric without the sky falling, the heating industry could also
Living the hydronic dream0
