Getting a very old gas fitting unscrewed
park789
Member Posts: 1
in Gas Heating
I have a firing ring for a gas pottery kiln that I need to send to Seattle to get refurbished. It has a set of gas fittings sticking out from the ring that I need to take off. The reason is that I can simply then ship it as a regular package. Otherwise the freight cost would be prohibitive and I would have to drive it over there which I don't want to do. It's a reducer black pipe fitting with ancient pipe dope on it. No rust but it is 37 years old. How do I get it to unscrew? A 24 inch pipe wrench has not worked and it has been drenched in WD40. Suggestions would be most appreciated.
Is this a bushing with a hex shape (six flats)?
I find the following works on most stuck threaded fittings:
Liquid wrench or PB blaster
Hammering or Impact
Wiggle in both directions (tighten and loosen)
The idea is to crush the corrosion between the threads.
If it is a hex shape, a socket and breaker bar would allow you to wiggle it back and forth. Tapping on the fitting with a hammer will sometimes break the corrosion between the threads.
Could you take it to truck or tractor repair mechanic?
If you attach a picture we may have some additional advice.
Slice the reducer with a 4 1/2" grinder with a cutting disk0
I removed a 60 year old galvanized pipe in to a galvanized tee and a galvanized pipe in to a brass union on a laundry tray a few months ago when replacing some galvanized pipe with copper at my mom's house without a problem.
What size are the fittings? A 24" wrench is only good up to 1" or so for assembly and maybe 3/4" for disassembly.0 -
I agree with Ed.To big a wrench and you will egg shape the pipe a picture would help sometimes heat will work depending on the piping material and make sure the gas is purged out0
3 foot wrench and 10 foot breaker bar with two guys hanging off the end, been there done that2
