FOUND - 3/8" FPT Fusible Inline Valve specs I was looking for - FYI oil burner - steam heat
LS123
LS123 Member Posts: 476
Hello and good morning...
I was looking for specs for 3/8" FPT Fusible Inline Valve for oil burner and found them.. posting as FYI -
SILVER 100F installed
GOLD 150 installed
See pic below.... Best \-LS123
Thank you!
@LS123
    EBEBRATT-Ed Member Posts: 18,243
    I always thought 165 was the standard temp. Never new they made 200 deg hand wheels
    LS123
  • LS123
    the temps you are referring to before install on oil line next to the burner..... install has silver fuse at 100 F and gold at 150F.... I hope I am correct on that.. thanks!
    Thank you!
    @LS123
