Not New,but WHY? sound of electrodes for first 45 to 60sec. Flame is on from start
LS123
LS123 Member Posts: 476
hello!
I was wondering if it is normal for the to hear the sound of electrode for about first 45 to 60 seconds... then sound goes away... and it seems like flame gets brighter once the clicking noise from electrodes stops...
As far as I remember it was like that....Is this normal? just wondering...
thank u ans best!
\-LS123
Thank you!
@LS123
  • STEVEusaPA
    Oil? Depending on primary control and how it’s programmed, ignitor stays on during trial for ignition, then shuts off.
    LS123
  • LS123
    thanks @STEVEusaPA ... yes the burner is oil...i think the burner is from 2008.. use .85 GPH and 80 or 90...... Nozzle... I was wondering if it should be doing that ... perhaps and most likely things are working as designed and implemented.... thank you again!
    Thank you!
    @LS123
