Pipe dope - gone bad or new chocolate flavor?
lbeachmike
Member Posts: 215
Hey guys -
This tube is super old - like 20-30 years old ... but was sealed. I've only ever seen pipe dope in white. Is this no good? I'm not sure if it goes bad ... thanks!
Different types were lots of different colors. The most common conventional type is gray. Usually only the teflon type is white or off white.
I have cans that I am still using that are over 20 years old.0 -
Sounds like you are saying that this should be okay to use. Incidentally, is temperature the reason for using this stuff versus tape? Somebody told me not to use teflon tape when replacing my steam vent and to use this instead. Thanks!mattmia2 said:Different types were lots of different colors. The most common conventional type is gray. Usually only the teflon type is white or off white.
Mostly preference. On steam systems if you use a lot of it, like to replace sections of piping, the oils could interfere with the steaming of the boiler and need to be skimmed off. Tape if applied incorrectly can get in to things like gas valves and cause them to not seat properly or stick. Sometimes tape or a combination of both can seal damaged or poorly made threads better than just dope. If it will still spread and stick to the threads it should be fine. Dope is usually faster and easier to apply than tape.1
Pipe dope questions on this forum
ask "what is the best pipe dope" You will get thousands of answers. Dope only, dope with tape. tape first then dope. dope then tape then more dope. Blue monster tape, yellow tape white tape...............................................................................................................................................................................................................................................................It goes on forever
You know what? Use what works for you.
I agree if the dope hasn't separated or hardened up it's probably fine2 -
- 50 Industry Classes
