Endoscope/Borescope for finding plumbing leaks
deyrup
deyrup Member Posts: 62
edited January 2021 in Plumbing
I found one my plumbing leaks but I can't find the other because there is a board in the way. It looks like I can wrap an endoscope around the board. Are endoscopes good for finding leaks in hard to get to locations or are they best for just going through pipes internally? Should I try to find the leak by sticking the endoscope down the pipe?
For the leak I found is the normal fix for a tub drain leak to just replace the drain or do I need to replace the whole tub? I would expect that you could fix the leak either by replacing the pipe or replacing the drain and the tub matters itself matters little unless there is a hole straight through.
    EBEBRATT-Ed Member Posts: 20,128
    Cast iron tub is probably ok. Getting the drain out is a little difficult. I would change the drain wire brush and paint some rust spots on the bottom of the tub
    mattmia2 Member Posts: 16,606
    When the wrench breaks the bars off the inside of the drain, there is a tool that is like an inside pipe wrench that will grip the drain from the inside walls so you can unscrew it from the shoe. It actually probably just needs a new gasket but might as well replace the whole trip lever assembly while you're in there. I suppose it is possible that the tub is cracked, but otherwise it is replaceable.
    hot_rod Member Posts: 27,396
    you often end up damaging the spud, so plan on replacing the entire waste and overflow Most are plastic these days
    A bore scope or sewer camera are good for searching inside or outside the pipes
