Cycle Time
MikeBos
MikeBos Member Posts: 26
I cringe every time I hear my Buderus G115WS/4 cycle on for 1-2 minutes and shutdown after the thermostat stops calling. This can happen multiple times an hour. Mainly happens when the in floor thermostat calls for heat to maintain 70f. Struck me that maybe a thermostat might include a setting that would allow me to define the minimum call cycle time. So instead of 1-2 I would set it to run for 5 minutes regardless if the floor was still in need. I have the diff for the aquastat set at 30f and high at 170f so floor only fires the boiler if boiler is less than 140f. Does any of this make sense? On the other side of things I'm still considering a buffer tank but that is lots of $$ whereas a new thermostat is not lots of $$. THX
