1725 RPM Motor replacement recommendations please...
swihart_art
swihart_art Member Posts: 39
My oil furnace has been tripping the safety switch on the motor lately... that motor is probably 40 years old and it trips once a week or so... can anybody recommend a good source to buy one online to replace it? Here is what I know about it:
- Burner is really old, pump is a newer (4 years max and changed coupler too) 1725 RPM so I'm assuming it needs to match.
- Not sure how many HP it is but I see lots of 1/6 and 1/7 motors used on Becketts
- Little red button pops out so something is overloading it or it's just old... I see no oil ports on it so think it's sealed.
    mattmia2 Member Posts: 16,460
    I think that @EdTheHeaterMan has a signature line that covers this
    EdTheHeaterMan Member Posts: 12,034
    edited January 2021
    I do have a signature line that covers that. LOL
    This is your motor.
    https://www.supplyhouse.com/Century-XEL2014-5-5-8-Oil-Burner-Motor-115V-1725-RPM-1-6-HP
    But it may not be. Check the dimensions.
    And after you replace that motor and the same thing happens, What will you check next?
    Check the pump strainer and the oil filter and the burner fan. If there is a build-up of foreign matter, then cleaning it might help. That costs less too.
    swihart_art
    Jamie Hall Member Posts: 27,237
    I don't suppose there is a nameplate on the motor somewhere?
  • swihart_art
    Check myself for not properly troubleshooting... :D
    It's somewhat loud too... "growl"... we've had that furnace for 40+ years and that motor is original so not surprising, I think the bearings are worn and it overheats at times... just wondering if there is a go to place online that someone can point me to for affordable replacements, I'm searching now and there's lots out there and the pricing is wildly different...
    Check the voltage at the motor with it running too, make sure a loose connection or bad contact in a control hasn't caused it to try to run on low voltage and overheat
    swihart_art
  • swihart_art
    This is your motor.
    Thanks for the tips, I just changed nozzle and oil filter while I was up there but didn't check/clean the strainer... fan is clear of debris, appreciate your help with the link...
  • swihart_art
    Will do, another good tip, that's why this place rocks, lotta good info on these boards... thanks!
    Most 1940s and 1950s oil burners used the same standard oil burner motor. https://www.supplyhouse.com/Century-XEL2014-5-5-8-Oil-Burner-Motor-115V-1725-RPM-1-6-HP You are probably correct about the 50+ year old motor. Especially if you never added any oil to the bearings. (Permanently sealed or not)
    Steamhead Member Posts: 18,404
    @swihart_art , can you post a pic of the burner? Many burners did/do use standard motors, but you never know...............
    Consulting
    EBEBRATT-Ed Member Posts: 20,085
    The frame # off the name plate will tell the story
