How to remove tank oil level indicator
rgar98
rgar98 Member Posts: 66
Hello,
Is there a way to remove a non-functional oil level float indicator from a tank?
  • LS123
    LS123 Member Posts: 476
    @rgar98 please send a PIC... if it is a standard one it is very easy assuming its not rusted and previously damaged
    Thank you!
    @LS123
    HVACNUT Member Posts: 7,451
    The indicator is just the vial with the measurements. The float is the gauge.
    Is it just the gauge, or is it a combi vent alarm?
    Gauge alone, you might be able  to pull the whole float assembly out (careful, its going to be messy), then unscrew the bushing. If not, hold the float up while wrenching so it doesn't get caught up on the sides.
    Use pipe compound only, no tephlon tape.
    And if your interested, there are wireless gauges with transmitter, receiver, or through an app.
    STEVEusaPA
    EdTheHeaterMan Member Posts: 12,190
    edited January 2021
    here is what HVACNUT is referring to.
    LS123
  • LS123
    thanks @HVACNUT ... especially thanks to @EdTheHeaterMan ... for step by step with pictures..
    Thank you!
    @LS123
  • rgar98
    Thanks for all the responses. My gauge is in integrated into the base of the vent pipe. I think it would require "major surgery" to remove it.
  • LS123
    @rgar98 picture would be helpful... if possible. thanks...
    Thank you!
    @LS123
