Old mercury Prestol..there is a dial way back NOT attached to anything.should it be??
LS123
Member Posts: 476
Hello,
for some reason, I felt like my PresTol is not working right... I put a new pig tail, waiting for new 3 PSI pressure gauge which will be tomorrow... pipes are all clean...
I tool the PresTol apart to clean and take out the gunk and oil on the bottom mount....
I notice way way back there is a dial like a hand of a clock, but not attached to anything.
Not sure if it should be? it can move toward both left and right... not sure when I used my compressor air gun to blow dust, it the dial came out of something it should be connected to. Picture below. Dial highlighted in red... also I notice one of the springs kind of bent
Thank you!
Thank you!
Was that glued to the arm with the mercury switch somewhere such that it acted as a pointer to show the current pressure when the cover was on?0
Are you referring to the hanging needle in the back on the right side?
That is the pendulum indicator for leveling. Works like a plumb bob. Line it up with the mark on the bottom of the case to be level....necessary to do with the HG switch.
The spring would be compressed/bent as it is cocked like the hammer on a gun waiting for the steam pressure to pull the trigger with pressure increase which will trip the bulb to the off position. IMO3 -
This ^^^Br. Jamie, osb
@JUGHNE yes... that is what I was referring to. thank you SO very much... I was worried that I might have to spend another $150 to get a new one... just got some Gorton #2 main valves, sight glass replacement kits, etc.. for $300... its definitely worth it....
I love this site and the knowledge I have gathered is significant... @mattmia2 please see above JUHNE info about my original post0 -
That mercury switch will last another 70 years. Can you buy replacement diaphragms for those?0
- 123 Chimneys & Flues
