The mid- and long-term future of photovoltaics
    hot_rod Member Posts: 25,909
    Doubling the efficiency would be a huge step for PV. Does the raw material come from only the Ural Mountains :)
  • Sal Santamaura
    Sal Santamaura Member Posts: 543
    hot_rod said:
    ...Does the raw material come from only the Ural Mountains :)
    No, it's found in multiple places, including Arkansas:
    https://en.wikipedia.org/wiki/Perovskite
  • jumper
    jumper Member Posts: 2,479
    I wonder what percentage of a home's PV installation cost is from the solar panels themselves? All that electric gear; marketing; permitting; labor; and so on must add up.
  • Sal Santamaura
    Another step that could increase distributed photovoltaic's viability:
    https://finance.yahoo.com/news/gaf-energys-easy-install-solar-232854799.html
  • Hot_water_fan
    Hot_water_fan Member Posts: 2,229
    Very little to be gained on the panel side for residential (utility too for that matter). Constraints on the transmission side of things are a big deal, the power itself is dirt cheap for utility scale. On residential, it's the businesses themselves. Looks like 500,000 households got solar installed last year so it's chugging along nicely, but a bit player when compared to the over 20 GW of utility scale solar installed in the US in 2021.
    Daveinscranton
  • jumper
    Biggest electric consumption in sunny places is air conditioning.
    I see many people buying batteries for solar electricity storage.
    But thermal storage will always be less expensive than batteries.
    And will last longer. Indefinitely.
    So I think that in long run photovoltaics will make ice. No stinking inverters.
