Air in baseboard heating
Rod118
Member Posts: 4
in Oil Heating
Hi all
im trying to bleed air out of my baseboards because they make that gurgling sound. I found videos on YouTube that show booking a hose up to a discharge spigot and manually turning on the zone valve. That’s my problem..I can’t find the zone valve. I have a 1 zone system..a New Yorker oil burner...around a 1993 vintage lol. Any tips would be appreciated.
If you have only 1 thermostat then you don't have zone valves Do everything in the video except the zone valve part.
You may have more than one loop on the zone if your home is larger. There should be separate purge valves to connect the hose to. Or at least some type of valve to direct the water thru one loop at a time.
Mr. EdEdward Young Retired
Ok will do...thank you. Home isn't too large (1600+-sf). I’ll try it tomorrow..thanks for your help0
Thanks Ed... took care of it this morning with no issues.0
Thanks for the update. We like the feedback here on the HH Wall
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
