Time for a new radiator?
Yes, top valve open, I haven't raised the water level to the top valve yet because the water that is currently in the site glass is still sitting there.
I will go see if I can clear the lower tapping - you're probably right.0 -
Yup! It was just clogged -thank you !0
Ok good deal, the sight glass skim is less effective because it's a smaller opening so be patient.
I will also note that the sight glass drain valve like Gordo suggests in that sight glass installation video is very good for preventing the buildup in that lower tapping. When I blow down from that valve there is always a notable amount of sediment in there that would otherwise just sit and ossify.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 75 Pipe Deterioration
- 15.6K Strictly Steam
