Time for a new radiator?
2»
  • SteamIsNotMyThing
    SteamIsNotMyThing Member Posts: 27
    Yes, top valve open, I haven't raised the water level to the top valve yet because the water that is currently in the site glass is still sitting there.
    I will go see if I can clear the lower tapping - you're probably right.
  • SteamIsNotMyThing
    Yup! It was just clogged -thank you !
  • Dan_NJ
    Dan_NJ Member Posts: 268
    Ok good deal, the sight glass skim is less effective because it's a smaller opening so be patient.
    I will also note that the sight glass drain valve like Gordo suggests in that sight glass installation video is very good for preventing the buildup in that lower tapping. When I blow down from that valve there is always a notable amount of sediment in there that would otherwise just sit and ossify.
