How much edge insulation is enough?
hot_rod
hot_rod Member Posts: 26,997
With snow on the ground today I thought I would take a look at my radiant with the IR camera. My office wall is ICF 2' deep up 4 feet. The block is an honest 2 & 2-1/2" of foam, 6" concrete. Supplying about 100°F to the slab.
vibert_cLard
  • TAG
    TAG Member Posts: 799
    That's very interesting ... I should get a simple IR device.
    Have had properties shot -- My guess is the big delta is the reason. Do you know the R of that foam?
    Have used closed cell on my projects for years and 2.5" at normal temps (70) is amazing when I have had audits done.
    Jamie Hall Member Posts: 26,972
    Neat! Thanks, @hot_rod !
