Honeywell zone valves
DENNISSERVICE
Member Posts: 1
I'm trying to find the white balls that are used to replace the black rubber balls in side the valves. Anyone know where I can find them.
Any supply house. Google 'Honeywell zone valve replacement parts".
What is the difference ? First time I heard they was an replacement ..
Are these the new enough type that allow you to change the motor/gears without having to drain the system and opening the wet side?
If not seems like changing the entire zone valve would be in order. IMO0
- 50 Industry Classes
