Honeywell zone valves
DENNISSERVICE
DENNISSERVICE Member Posts: 1
edited December 2020 in THE MAIN WALL
I'm trying to find the white balls that are used to replace the black rubber balls in side the valves. Anyone know where I can find them.
  • STEVEusaPA
    Any supply house. Google 'Honeywell zone valve replacement parts".
  • Big Ed_4
    Big Ed_4 Member Posts: 3,342
    What is the difference ? First time I heard they was an replacement ..
  • JUGHNE
    JUGHNE Member Posts: 11,508
    Are these the new enough type that allow you to change the motor/gears without having to drain the system and opening the wet side?
    If not seems like changing the entire zone valve would be in order. IMO
