Lochinvar tech support
smklin
Member Posts: 69
Does anyone else have a problem getting through to Lochinvar tech support
Have a few KBN399 hooked up in a cascade system. Had to change the main control board because of a power issue. (Was nothing wrong with it) It seams like the leader can't find the rest of the boilers . Any ideas any help would be appreciated .
It's been a couple years so my memory is a bit fuzzy. The process is pretty well laid out in the manual. One boiler is the lead and the others follow. You can also set a boiler as backup lead in case the main lead goes down.
What issue are you having?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
communication between boilers0
