Heat Issue
2»
  • HeatNovice
    HeatNovice Member Posts: 29
    You first comments, that is a job for an electrician?
    Your second comment-where is the circulator with lights?
    Thx for your continued efforts.
  • neilc
    neilc Member Posts: 3,038
    1,
    an electrician, or a heating guy(person), or a handy HeatNovice type guy, if you're comfortable with it, and turn off the power, but if you're asking , , ,
    2,
    no, not a circ with lights, the other end of the power cable,
    follow that circ cable back to its other end,
    I am expecting a box on the wall, or side of the boiler, or,
    , , to where ever it ends and gets its power,
    3,
    we'll get there
    known to beat dead horses
  • HeatNovice
    It goes to this box.
  • neilc
    ummm,
    my eyes are blurry,
    and maybe a second shot from further back?
  • HeatNovice
    Photo further back.
  • HeatNovice
  • neilc
    so do you feel comfortable slipping the cover off of that relay box? and post that head on picture,
    and do you have meter to poke around in there a bit?
    we're trying to figure out if 120V is going to the circ when you turn up the thermostat upstairs.
    I'm quitting for the night, merry christmas
  • neilc
    so if you turn up that thermostat, does it get boiler hot in the attic?
  • HeatNovice
    Neil, I’m back on forum!!  Just turned up heat and am waiting.
  • HeatNovice
    I have a thought. I have another room in house that I don’t use often, the same AHU serves the top floor and also this “seldom” used room. In this room, I regularly leave thermostat at 50 degrees. Could this be impacting my second floor heat deficiency?
  • neilc
    the plot thickens , , ,
    now you have 2 trips up to the attic you owe ,
    one for each thermostat,
    if the first thermostat we've been discussing doesn't get boiler hot up there, then try that second tstat,
  • HeatNovice
    will do and advise. Sunday. Thank you.
  • HeatNovice
    I was going injured today while in attic. I will have to heal and go back up.
