Heat Issue
You first comments, that is a job for an electrician?
Your second comment-where is the circulator with lights?
Thx for your continued efforts.0 -
1,
an electrician, or a heating guy(person), or a handy HeatNovice type guy, if you're comfortable with it, and turn off the power, but if you're asking , , ,
2,
no, not a circ with lights, the other end of the power cable,
follow that circ cable back to its other end,
I am expecting a box on the wall, or side of the boiler, or,
, , to where ever it ends and gets its power,
3,
we'll get thereknown to beat dead horses0 -
It goes to this box.
ummm,
my eyes are blurry,
and maybe a second shot from further back?known to beat dead horses0 -
Photo further back.0
so do you feel comfortable slipping the cover off of that relay box? and post that head on picture,
and do you have meter to poke around in there a bit?
we're trying to figure out if 120V is going to the circ when you turn up the thermostat upstairs.
I'm quitting for the night, merry christmasknown to beat dead horses0 -
so if you turn up that thermostat, does it get boiler hot in the attic?known to beat dead horses0
Neil, I’m back on forum!! Just turned up heat and am waiting.0
I have a thought. I have another room in house that I don’t use often, the same AHU serves the top floor and also this “seldom” used room. In this room, I regularly leave thermostat at 50 degrees. Could this be impacting my second floor heat deficiency?0
the plot thickens , , ,
now you have 2 trips up to the attic you owe ,
one for each thermostat,
if the first thermostat we've been discussing doesn't get boiler hot up there, then try that second tstat,known to beat dead horses0 -
will do and advise. Sunday. Thank you.0
I was going injured today while in attic. I will have to heal and go back up.0
- 109 Chimneys & Flues
- 977 Plumbing
- 387 Solar
- 17 Recall Announcements
