motor off delay
xtrm4x4
Member Posts: 2
What are the benefits of the motor off delay? I have a Beckett Genisys controller.
If you're using motor-off delay, you also need two "hot" wires feeding the GeniSys- one that goes through the safety limit controls and one that does not. If your unit already has this feature, great. If not and you're looking to upgrade, call a pro.All Steamed Up, Inc.
Consulting0 -
Thanks for the great info0
