Burnham ES2
jmcnulty89
jmcnulty89 Member Posts: 10
edited December 2020 in Gas Heating
I had a burnham ES2 gas boiler installed nov 2018 it keeps going to status 15 (waiting for limit to close) and I have to press a switch on the back of the boiler to get it back up and running talked to the contractor who installed it he said it’s normal something to do with high pressure outside and not being able to vent it’s hooked up to a normal chimney with a ss liner installed same time this does not seem normal to me happened 5x last 24 hours located Long Island New York cold and wet weather
sorry for long post and help is great key appreciated wife and kids are cold
    Steamhead Member Posts: 18,410
    That's probably a "blocked-flue switch" doing its job. Have the chimney checked.
    Consulting
    HVACNUTZman
  • jmcnulty89
    I was thinking that but when the installer said your the 60 call since 10 pm last night so I’m jousting see anyone else have this problem or more insight
