Tips for Improving Short Cycling?
I'm going to buy one of those Macromatic TR-6512U and give it a whirl. I took a look at the datasheet and don't see any mounting features.
How do you guys mount it? I suppose I could always use an epoxy adhesive if I had to.0 -
Make sure you also buy the mounting socket for the timer. It doesn't come with it.
I just zip tied my assembly to the gas line, as that was the closest rigid thing to the control wiring j-box on my setup. The mounting socket also has places for mounting screws, so that's an option too.Burnham IN5PVNI Boiler, Single Pipe with 290 EDR
18 Ounce per Square Inch Gauge
Time Delay Relay in Series with Thermostat
Operating Pressure 0.3-0.5 Ounce per Square Inch0 -
Best thing is to put up a piece of DIN rail somewhere. Almost everything mounts to that now - terminal strips etc. I am perpetually in a state of experimentation so it is nice to just be able to clip on a new device.AdmiralYoda said:I'm going to buy one of those Macromatic TR-6512U and give it a whirl. I took a look at the datasheet and don't see any mounting features.
Attached are photos of the whole unit and just the base on a DIN rail.
There are also 2 holes you can see to screw the base into anything.1926 1000EDR Mouat 2 pipe vapor system,1957 Bryant Boiler 463,000 BTU input, Natural vacuum operation with single solenoid vent, Custom PLC control1
- 116 Geothermal
- 15.8K Strictly Steam
