Oil Tank Fittings
kcopp
Member Posts: 4,598
in Gas Heating
Is it allowable by nfpa code to use Megapress fittings on oil tank piping...vent and fill? Viega allows them as per their testing. I have seen a few tanks done this way but I was unaware that they got the final goodhousekeeping stamp of approval?
MegaPress G.
I think it's in the new code, (I didn't get my latest yet), whether local AHJ's will adopt it yet is a whole other question.
I'd print/bring Viega's info with you for the permit.
I've been thinking about this too. Basic cost for just 1 1/2" male adapters and using regular elbows/nipples to make swing joints, etc., seems to add about $450.00 to the job.
The only reason I got the RP340 was for tank jobs. Getting to old to drag the threading machine around.
Last I knew it was not approved here in New England. Got My concerns on the o-rings with fuel/bio. Viton can be hard to come by.0 -
Same one I'm using, very nice, right? I wish the tool and batteries/charger came in one case, and the heads were all in another case. Gotta loosen up before I pick it up...lol.BDR529 said:The only reason I got the RP340 was for tank jobs. Getting to old to drag the threading machine around.
How does Mega Press give you a swing joint?0
It doesn't. That's why I said male adapters.EBEBRATT-Ed said:How does Mega Press give you a swing joint?
Press X Male adapter, regular elbow, close nipple, regular elbow, Press X Male adapter.
Adds up quick $$$.There was an error rendering this rich post.
Press is allowed under NFPA31 2020
To learn more about this professional, click here to visit their ad in Find A Contractor.2 -
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
