Rinnai error code 19
mhunter514
mhunter514 Member Posts: 3
Good afternoon, I have a Rinnai V75e that came with my newly built home 2 years ago. For the past 6 months I get a beeping and code 19 which I looked up and saw is an electoral grounding issue or short. Had a plumber come out 3 times and never got it fixed. It's like going to the doctor when something hurts but when you get there you feel fine. So every time it happens now I go out and smack the side and most times it starts working. Anyone ever hear of anything like this? I'm ready to hire an electrician but wanted to check around first.
  • mhunter514
    Would have helped if I spelled electrical correctly. lol
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,082
    Hi, If smacking the cabinet helps, it suggests a loose ground connection. I’d trace down and clean up any ground connections you can find. See if that helps. And, electors are in the news. :D I think we knew what you meant ;)
    Yours, Larry
  • mhunter514
    Thanks for the quick response, this has just been a nightmare to deal with.
