VS circs with ECM, permanent magnet motors
Steve Minnich
Member Posts: 2,878
Do you think manufacturers should provide minimum water quality requirements when using these circulators?
Should they require that they're installed along with magnetic separators?
Or, other filters that remove black iron oxides?
Some circ manufacturers mention water quality in their installation instructions. Others, not a word.
Steve Minnich
That's along the lines of what I was thinking. At some point, I think it needs to be a bigger part of the discussion. LOTS of talk of water quality as it pertains to modcons, not so much for these circs.Steve Minnich0
If it weren't for what's been posted here in the last couple of years, I would not have been aware of it.
To be honest, I usually don't use an ECM with a boiler replacement in an old CI system, though we provide dirt separation. Most all of our ECMs go on new systems with copper/pex.Bob Boan
That’s really only the safe way to do it.Steve Minnich0
I think B&G has a water spec published. But I don’t know how you would set a number for magnetite, which seems to be ECM challenge?Bob "hot rod" Rohr
I agree. Grundfos touches on it a little.I learned the hard way, but it didn’t take me long to learn it. It just seems to me there should be a forewarning of sorts.The number of failures has to be significant.Steve Minnich0
What does Grundfos have to say about it? I have three Alphas in my system and don't remember anything in the manual about water quality. My system is filled with raw well water, but I did use the Fernox boiler commissioning kit with it.0
@Robert_25 I copied and pasted this from the Alpha 2 instructions.
The pump is suitable for the following liquids:
• Thin, clean, non-aggressive and nonexplosive liquids, not containing solid
particles or fibers.
Remember, I said touched on it.
Steve Minnich0 -
I’d like a copy Steve, permission to use in the water quality standard we are working on with IAMPOBob "hot rod" Rohr
- 50 Industry Classes
