Caleffi Non-Thermostatic
Zman
Member Posts: 7,609
I am troubleshooting a system which has a 3/4" Caleffi 521 thermostatic mixing valve in a location where a non thermostatic valve would be more appropriate. Does anyone ( @hot_rod) know if there is a caleffi model available that would be a plug and play solution.
Albert Einstein
Albert Einstein
A manual 3 way mix or motorized?Bob "hot rod" Rohr
I think manual would do the job. It would be nice if the same valve would accept a motor."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 50 Industry Classes
