Caleffi Non-Thermostatic
Zman
Zman Member Posts: 7,611
edited December 2020 in THE MAIN WALL
I am troubleshooting a system which has a 3/4" Caleffi 521 thermostatic mixing valve in a location where a non thermostatic valve would be more appropriate. Does anyone ( @hot_rod) know if there is a caleffi model available that would be a plug and play solution.
Albert Einstein
    hot_rod Member Posts: 26,588
    A manual 3 way mix or motorized?
  • Zman
    I think manual would do the job. It would be nice if the same valve would accept a motor.
    Albert Einstein
