New Steam System Owner Looking for Advice on Improvements
No pumps. It is the OG return pushing 90 years of service. I am not a fan of the return being behind my main breaker. I contacted my local steam guy(not a plumber) as suggested by @Fred. He should be here anywhere from 1500 to 1700 since he lives in neighborhood. Again thank you all for your help. The feedback has been great!0
I am looking at your gas hot water heater tank....nothing to do with the steam heat.
I notice the copper return to the bottom of the water heater tank, it looks like hot water gravity recirculation system.
I have that system myself, how does yours work for you?0 -
It seems to be fine... I dont know anything else tbh. So I am not sure if it is a wedgie0
and what is the picture with the wet stain on the floor, coming from the wall?
what's leaking ?known to beat dead horses0 -
Leak was caused by an under ground pipe (Going to replace with "new return"-PEX Tie feed line into the new wet return to work as hartford loop.)
Found Main Vent... It is stuck shut and nearly impossible to get at. (put large vents on the end of line radiators)
Replace Elbow with a T on Near boiler piping to work as another equalizer.
Though I have some water damage does anybody know how best to put it toward an insurance agent?0 -
What is your insurance deductible amount?
What I have seen in your pictures look to be pretty minor in damages.0 -
2500. That is seepage I have some carpet that is peeling up and a floor that is bubbling up.0
Damage from pipe covered. Going dry return with a big vent. Increasing header height. Flipping equalizer so it makes sense. I will share photos upon completion.0
Yeah the 1/2" return pipe supports, I never saw those before. Better than bent nails I guess0
Ed, I first saw that pipe stub support in a 1932 and 1938 building.
Leads me to believe that was the original path for returns here.
Holes probably made with a star drill and 2 lb hammer....anyone remember that method?0 -
well once the repair is done I am going to keep the original return there as décor0
@JUGHNE
Most people wouldn't know a star drill unless it hit them between the eyes. There is a reason the old jobs didn't have many anchors!!!
The other place I notice the same thing is duct work. Now everyone is happy to shoot screws. In the old days with a corded drill with a 1/8" drill bit, an awl and a flat head screwdriver the duct work didn't get many screws or hangers.
I started in 73' at an oil company, it was common to service oil burner running that had been installed in the 20s & 30s, real soot makers. Oil was cheap, no one had any incentive to up grade
My boss had been hired by the same company in 1946. He told me the first job was threading 2" pipe by hand for two weeks straight. They were too cheap to buy a threader and labor was probably $2.00/hr0
- 87.7K THE MAIN WALL
- 128 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
