CI rad loop pressure drop
kensheets2
Member Posts: 36
Hello,
I have a 3/4" pex loop for cast iron rads. Im pressure testing before I close everything up. Piping stubbed out with caps, no rads attached. Have a valve on return side and was able to bleed air out.
I pressurized with garden hose and was able to get to 78psi. Over two days it has dropped approx 6 psi.
I see no leaks at fittings so is this drop acceptable?
Thanks
Thanks
So both sides are closed with a valve or the water is constantly pushing?
Of so your pressure readings would be affected by pressure drops on the city water line.
Possibly. It does suggest a very slight leak somewhere -- but if you really got all the air out, the leak could be truly tiny. Water is almost -- but not quite -- incompressible, and the radiators are also, of course, so the main volume change would be from the PEX, which isn't all that elastic itself. It could also be, now that I really think about it, from the PEX taking a set under pressure, with no leak at all...Br. Jamie, osb
Did the temperature drop by chance? 10 degrees might cause a 6psi drop. With PEX, air can tend to leak out where water wont (bigger molecule). If it’s stubbed up and capped I don’t see how you got all the air out.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
