Pipe Hanger Noise
fxrgrunt
Member Posts: 157
So at the recommendation of the forum prior to insulating my steam pipes again, I re leveled the pipes because the asbestos abatement guys had cut about 4 pipe hangers. I went with clevis hangers with 3/8 rod and used the sammy sidewinders to mount them as high in the joists as possible. Still, I get popping noise from them when the pipes are expanding/contracting. Any advice as to get rid of the noise? I know I could get the wood blocks and bigger clevis hangers to go over the insulation but I'd like to get through winter before doing that.
Try using a piece of plastic like from a milk jug between the pipe and Clevis hanger , is it possible that you don’t have enough hangers and have excess weight on the offensive hanger . On 2 inch pipe I generally get a hanger every 7 to 8 feet apart and I don’t rely on pipe that hung to support pipe that has no supports . Peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating2 -
Steam will melt the plastic. A racecar buddy of mine has this stuff in his garage. I used it to wrap steam pipes near the hangers once and it did a good job of reducing the expansion noise. https://www.summitracing.com/parts/the-11153?seid=srese1&gclid=CjwKCAiA-_L9BRBQEiwA-bm5fogDPA9HctIkgaMIy1hL8KSBALn4ABOe-Ru_JsVIhxnRy8ZmCsymZBoCfDAQAvD_BwE
Won't get rid of the hammer from improper pipe slope.Edward Young Retired
Steam doesn't seem to melt milk jug plastic. Most of it is https://en.wikipedia.org/wiki/High-density_polyethylene which melts at 130c
But for me the challenge is finding where the noise is happening!NJ Steam Homeowner.
See my sight glass boiler videos: https://bit.ly/3sZW1el3 -
ethicalpaul said:Steam doesn't seem to melt milk jug plastic. Most of it is https://en.wikipedia.org/wiki/High-density_polyethylene which melts at 130c But for me the challenge is finding where the noise is happening!0
EdTheHeaterMan said:Steam will melt the plastic. A racecar buddy of mine has this stuff in his garage. I used it to wrap steam pipes near the hangers once and it did a good job of reducing the expansion noise. https://www.summitracing.com/parts/the-11153?seid=srese1&gclid=CjwKCAiA-_L9BRBQEiwA-bm5fogDPA9HctIkgaMIy1hL8KSBALn4ABOe-Ru_JsVIhxnRy8ZmCsymZBoCfDAQAvD_BwE Won't get rid of the hammer from improper pipe slope.0
Maybe...maybe not. I had the same situation, but adding hangers put additional stress somewhere else so for me it's been non-obviousfxrgrunt said:NJ Steam Homeowner.
ethicalpaul said:1
Agree, I think if the cross bolt is loose to swivel it may swing with pipe movement. I would put a locknut on the bolt or double nut.0
Did you try loosening the horizontal cross bolt on the hanger so that the sides are not touching the pip?0
Possible that the hangers are too tight pinching the pipe0
I use flattened soda cans as a bushing0
Oversized clevis hangers with tin shields to accommodate pipe insulation are typically used in the commercial piping industry. Then a piece of pipe sized calcium silicate between the pipe and the shield prevents the insulation from compression under the weight of the pipe. Not sure where you can get the calcium silicate, but maybe you can substitute something (wood or rubber). I think the larger hanger, if it fits, and good fiberglass pipe insulation may help with the noise.0
- 87K THE MAIN WALL
- 113 Chimneys & Flues
- 106 Geothermal
- 980 Plumbing
- 388 Solar
