Thermo Pride OL5-85 Combustion Chamber Cracks
Damon
Member Posts: 32
in Oil Heating
Hello I have an old OL5-85. I may be getting gas so it might go bye bye. It’s in a summer house so it has been rarely used. I was inspecting it and noticed some cracks in the HX. Are these a major problem? Thanks in advance.
Duh I wrote HX. Per the pics/title, the combustion chamber is what I meant.0
Before you go and replace the Thermopride with a gas furnace, you might want to consider the durability of the two. A Thermopride is probably the most durable forced air furnace available, and extremely reliable when maintained properly. I wouldn't be surprised your furnace outlasts many gas furnaces installed this year.1
I agree @STEVEusaPA missed that. One reason why I prefer Carlin0
Thanks for the input! The unit is 23 years old and will probably outlast me. It has been bullet proof and so easy to maintain which is why I originally had it installed. The only reason why I’m considering getting rid of it is to get rid of the tank in the basement which I need to move plus my electric hot water heater and sink as part of a rehab we’re doing which also requires all new supply ducting and an easy return mod. The tank is a single wall 14ga which I should probably switch to a Roth if I don’t convert to gas. I don’t need to move the HWH or sink if I install a vertical Roth. What I don’t like about the Roth is there’s no bottom tap to remove water. Having been involved in a $40k remediation of a leaking UST at another house back in 2003, I’m not going through that fun again.
I changed the nozzle and cleaned the burner before I posted. The flash made it look much much worse than it was. It wasn’t really dirty.
One last question, I know there’s a Wayne P250AF gas conversion kit for this which technical at TP said will drop the efficiency by 3 points at most. Otherwise they said the conversion was no big deal. Any comments on the gas conversion? Thanks!0 -
I haven't seen a gas conversion done on a Thermopride, but I'm sure it could work without any problems. Are you considering switching to natural gas or propane? It might be more expensive to run on propane, depending on your rates. Oil creates more BTUs when burned. Where I work I have had a few customers complain about the higher cost to heat their home with LP, even when installing mod con boilers and condensing furnaces.0
Natural gas.0
That unit has a Lifetime Heat Exchanger warranty.
Check with Thermo Pride before converting to gas. You might be better just getting there gas model0 -
Taken from the original furnace brochure: “All Thermo Pride octagon oil furnaces can be changed easily from oil to either natural or propane (L.P.) gas. For recommendations on selecting the proper burner, contact Thermo Pride”.
It was another reason I selected TP. I called TP. It's just a matter of cost since I don't have a chimney liner. I haven't looked into the cost yet as the furnace is just one aspect of the rehab.0
- 120 Geothermal
