How cold for above-ground LP tanks to have issues?
sunlight35
Member Posts: 35
What's the typical low temperature for above-ground propane tanks not able to provide sufficient gas pressure needed for boiler? My boiler requires a minimum pressure of 10 w.c.
As long as you keep it above 5% full, you'll never see weather cold enough to cause problems.0
That funny0
Above ground tanks usually don't have issues. I do have a client with a 4,000 gallon tank and over 6,000,000 attached load in climate zone 7. They have issues and need to run a vaporizer to make it work.
How big is the tank and boiler?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Yes the tank has to have enough surface area to be able to absorb heat to vaporize the liquid based on the connected load0
It depends on your btu load, and how full the propane tank is. Google "propane tank vaporization chart" and you will see what I mean.
At -45F you could store the propane in a 5 gallon pail.0 -
Thanks, I think I was mistaken w.c. for psi.0
I was on the maintenance team at Snowbird resort when it was first built, all LP boilers. The vaporizers were in a concrete vault in an avalanche path. Talk about a scary appliance to work on.Zman said:Above ground tanks usually don't have issues. I do have a client with a 4,000 gallon tank and over 6,000,000 attached load in climate zone 7. They have issues and need to run a vaporizer to make it work.
They finally ran a NG line up the canyon.Bob "hot rod" Rohr
Living the hydronic dream1
- 87K THE MAIN WALL
- 113 Chimneys & Flues
- 106 Geothermal
- 981 Plumbing
- 388 Solar
