Tekmar 351
I have a Tekmar 351 thermostat that needs to be replaced. I would love it for someone to explain how it really works in layman's terms, and what you recommend for a replacement.
  • STEVEusaPA
    Tekmar never had a thermostat 351. They had an injection mixing control, discontinued. So it’s hard to give advice until I (we) know which component you are referring.
    Take/post some pics.
    Zman
    EdTheHeaterMan Member Posts: 11,975
    edited November 2020
    The 351 control used an RTU-051 as a thermostat. It is a 2 wire digital devise that communicates with the 351. Not an analog switch that opens and closes.
    If you want to change the thermostats you will need to change the entire controller with something that will operate the injection pump.
    hot_rod Member Posts: 27,256
    It was a mixing control, had the ability to take an input from a remote sensor as @EdTheHeaterMan mentioned. It was a great control, showed up at a few of the radiant manufacturers offerings.
    Probably early to mid 1990's. Might be time to upgrade.
    tekmar keeps data on obsolete controls at their site.
