Are Maid-O’-Mist Jacobus Vents adjustable?
tomsloancamp
Member Posts: 88
I noticed the maid-o-mist steam vent has a cap that screws on (and off.) If I held on or read the manual I probably wouldn’t need to ask but is the cap adjustable? Does it allow you to adjust the amount of air release? If not, why is the cap there?
I don’t call it adjustable. But you can remove that orifice and swap it out with any other size they offer.
MoM are the same as Gorton basically, since Gorton copied the MoM vents (I think). They are both quiet and work well.
Don’t buy any vent from HD or Lowe’sNJ Steam Homeowner.
Maid O Mist sells a vent with all 5 orifices so you can select which venting rate by just unscrewing one and screwing on another.
This outfit has a great price right now -
https://www.eastcoasthardware.com/132292-maid-o-mist-maid-o-mist-18-steam-angle-radiator-valve-kit-0220-5l.html?utm_campaign=google&utm_source=google&utm_medium=cpc&gclid=Cj0KCQiAqdP9BRDVARIsAGSZ8Am1NV0YvnDF6XxB614qWMSI0L4vXS5ZmwGui3IozVrOpTbZkO6O8HcaAkRBEALw_wcB
3PSI gauge0 -
They're adjustable, in the sense you can drill them out to a larger size. That's what I did; bought 4's and 5's and drilled to suit. This post has the chart:
https://forum.heatinghelp.com/discussion/comment/1590569/#Comment_1590569
Harbor Freight sells a set of Micro drill bits that are great for this, small diameters with fine gradations.
https://www.harborfreight.com/high-speed-steel-micro-drill-bit-set-30-pc-61526.html1950's Bryant boiler in a 1-pipe steam system at 7,000 ft in northern NM, where basements are rare.1
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 966 Plumbing
- 385 Solar
- 15.3K Strictly Steam
