Honeywell primary & Allanson transformer
rgar98
rgar98 Member Posts: 66
Hello,
Is the Honeywell R7284U primary running in interrupted mode (used in an oil , forced air system), compatible with the 2721-628G Allanson transformer? I'm replacing a an old Beckett ignitor.
Thanks.
RG
  • BDR529
    BDR529 Member Posts: 376
    edited November 2020
    SHOULD work just fine.
    SuperTech
  • rgar98
    Thanks, I appreciate your response. I was concerned b/c I have a transformer in my furnace and NOT an electronic ignitor.
  • STEVEusaPA
    That transformer may out last the furnace.
    MaxMercy
  • MaxMercy
    MaxMercy Member Posts: 601
    With an interrupted primary either one will last nearly forever.
    SuperTech
  • SuperTech
    SuperTech Member Posts: 2,661
    And if your electrodes are in good shape they should never need replacement using interrupted ignition. I like to setup all my oil burners to use interrupted ignition.
    STEVEusaPAMaxMercy
